Detroit Radiator Handles
mtfallsmikey
Member Posts: 765
Threw many in the trash over the years...they would ususally split in two. do you have one that a woodworker could use as a pattern to make some replacements for? White Ash or walnut would work well.
Does anyone know where I can find some Detroit Radiator handles. The ones that are on are wooden with the metal plate beneath them with an "extension" downward that goes against two stops on the valve. They are 1/2 turn valves that you turn counter-clockwise until you hit the "stop" to open and to close you turn clockwise until you hit the opposite "stop". The valves I can make work, however the handles are either rotten or the metal plates beneath have rusted off over "many" years of slowly leaking packing nuts.
Thanks for your help.
Jerry0 -
vise-grip fit-all handles
or just replace the valves. nothing lasts forever. they put in their time.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
