is there a way to access old threads
geo_25
Member Posts: 1
A few days ago I was reading a thread that pertained to my radiant system setup. Now that thread doesn't show up because its more than 3 days old. I didn't bookmark it. Is there a way to access it?
It use to be you could from the link on the email sent to you after someone responded to your post. That is if you checked the box to receive the email.I have enough experience to know , that I dont know it all0 -
old threads
try a search with keyword. its the button above the main field,not google.--nbc0 -
if you were part of the thread
search (from the orange bar) using your name as author. If you add to the thread, it will appear back on the Wall.Retired and loving it.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
