expansion tank gravity system
Timco
Member Posts: 3,040
I have a cust with a gravity system working well, but it seems it has lost it's tank. Issue is, there is no pipe through the roof. My auto-fill runs up to 12 where it was set, and the pressure trips relief valve when hot. I have not seen a closed gravity system. Might the attic tank be a closed type?? Not a new roof or anything like that. I'd like to ID the problem with minimum attic time. Can a modern diaphram type tank be used with a gravity system? I cannot see a problem, but I may be missing something...
Tim
Tim
Just a guy running some pipes.
no expansion tank
One of my co-workers was at a job a while ago with the same issue. I believe,originally that the radiators were partially full of air, and were used for expansion. New homeowner move in and bleed the radiators. No air, No expansion.
But I don't see any problems with adding a diaphragm tank.0 -
Lost it's Tank?
Tim, Where did the tank go? It might be prudent to find the tank and associated piping, disconnect it and cap it, then install a diaphragm tank. I wouldn't ****-U-ME that it won't cause you problems in the future. .02 bobbob0 -
When I say "lost it's tank", I mean it is very sensitive to a small addition of water, and the pressure climbs very fast with the a call for heat. I have a plan to peek in the attic, but I have followed & accounted for all pipes in the basement, and none go to the attic. (small house) I did bleed the rads after I filled the system when I installed a new PRV / relief valve combo B&G unit.
TimJust a guy running some pipes.0 -
Check the attic, if this has a PRV on it, it has to be a closed system as you well know, my suspicion would be someone changed the open tank in attic to a "closed" tank when they changed it from a manual feed. They didn't necessarilly have to run the pipe from the basement, there may be an open pipe running from the tank to basement.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
