flue cover for new york oil burner
dutch2412
Member Posts: 14
the flue cover plate is steel.do i just make the cover as tight as possible? because the insulation i got from the supplier is one inch thick.{how tight to squeeze?}
Tight enough to seal, not overtight. If you overtighten nuts, the insulation board will be trashed and will need to be replaced very soon.0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
