fluid used
john_181
Member Posts: 93
Hi Bill,
I was just chating with Brad White and he told me to ask you this question. I just removed an old Hoffman outdoor reset control which was not being used any longer and I had to cut the capillary tube leading thru the wall and I smelled something like "pine" and it dripped a few clear drops. What kind of fluid did they use back then?????
Thanks
Thanks
Cap tube fluid
Most used denatured alcohol, as far as I know.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
