posting pics
Dan C._2
Member Posts: 54
every time i try to post a picture i get this message
Error:
Error processing CFFILE
The path, 'E:CFUSIONCFAppsForumsDataAttachmentstudor st..jpg', is illegal. Path specifications cannot include '..'
The error occurred while processing an element with a general identifier of (CFFILE), occupying document position (11:2) to (16:2) in the template file E:wwwforums.invision.netFormsAttachmentsEdit_Action.cfm.
Mail To:
Time: 09/24/05 19:45:11
Browser: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; .NET CLR 1.1.4322)
Remote Address: 209.6.193.207
HTTP Referer: http://forums.invision.net/Attachments_Edit.cfm?CFApp=2&Message_ID=191855
Template: E:wwwforums.invision.netFormsAttachmentsEdit_Action.cfm
Query String: CFApp=2
Billy,
There was a problem with picture posting last week. I believe as of Friday it was fixed per Dan H. So you might want to try again, it should be working.0 -
still not working
Where are you trying...
to download the pictures from. I notice the address starts with E: which on my computer is a CD disc drive. If you are trying to load from a disk, you might have to load the picture onto your computer hard drive first, such as on to the desktop, or the "My Pictures" file. Then try loading to the wall.
If this doesn't work, try e-mailing Dan directly at mailroom@heatinghelp.com0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
