Help -Split system AC
tim smith
Member Posts: 2,752
Look into the inverter drive mitsubishi split system, quite a cool unit. Good luck, Tim
Help Split System AC
Hi Guys you have be great help visa v steam but I have a AC question. I need to AC bottom floor. I'm in Queens and local AC guy deals in Friedrick products. Choice is 12M to 18M Split system or 12m to 18m portable`unit. The portable is louder but cheaper.Has anyone had any of these systems installed Friedrick's or other with good results. It's going to happen I just would like to hear so feedback about reliability and brand.Thanks Jim0 -
Reliability and brand
A few things, Jim.
1 - Friedrich has been one of the, if not the, major players in the window air conditioner side of the industry.
2 - The quality of their split systems seems to be inline with that of their window equipment
3 - When installing a split system, it becomes part of the structure and, although it may be more expensive from a first cost standpoint, it increases the value of the structure.
4 - Personally, I would go for the split system
5 - There is an area at the bottom of the wall called "Ask Professor Silberstein" for your air conditioning and refrigeration questions.
6 - Go with the split... from one Queens resident to another.
Best of luck.0 -
A question worth asking...
Is the Friedrich unit last years or this years. Friedrich's units are a private label for Fujitsu. Last years 12k was 11 seer. This years is 21 and just better all around. It will require a 20 amp dedicated circuit.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
