Steam pipes
jackchips_2
Member Posts: 1,338
a shocking reminder, Alan.
Many years ago, when starting to replace a 4" CI soil stack, I put the sawsall to it and was zapped pretty good. The entire stack was alive from a wire.
Not just heating pipes and I bet there are many of us who have had similar experiences with all kinds of piping.
Looking forward to wireless power. :-))
Jack
Jack
Steam Pipes
Are steam pipes supposed to be grounded with some sort of jumper from the pipe(s) to the house ground?
I understand the boiler itself is grounded, but what about the network of piping running around the perimeter of the cellar. Should a copper jumper cable be attached someplace directly between a steam pipe and bonded to the house's grounding system independently of the boiler's ground?
I have heard and seen conflicting theories on this.
What do you experts have to say?
Thanks0 -
Never
thought about it, but it's probably not a bad idea. If, for any reason a live wire were to come in contact with a heating pipe, the piping would become "live" and you could get a shock from it. If the pipes are grounded, it would blow the circuit breaker instead of electrifying the pipe.
Doesn't that create an alternate grounding loop/path that could defeat the boiler's ground?0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
