oil heating system blower (who's right?)
Tony Melo
Member Posts: 6
quick question: I was talking to a friend about oil heating systems and this friend insisted that the blower on these systems are used only to "evacuate" any fumes in the boiler. I told the him that its was for combustion & atomizing the oil into a fine mist for burning. WHO'S RIGHT?
You are.
oil burner motor
Tony you are right ask your friend what would happen to the oil without the blower0 -
thanks
I can't wait to rub this in his face. thanks guys
tm0 -
don't be too quick
Are you and your friend on the same page? he may be talking about a power ventor(which would be used for evacution of flue gases.)If he wasn't, now he can say he was:-) which makes you both right.0 -
both right
You are more right, but prepurge and postpurge cycles are very important and the fan does that as well.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Since 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
A REAL GOOD PLUMBER, INC
NYC LMP: 1307
O:212-505-1837
M:917-939-05930 -
Chim-Chim-anee
Had this discussion a long time ago with an "oil burner pro"..Burner fan is for combustion, chimney is for removing the flue gas from the appliance (or a power venter)..or, as some call it in my area: Chim-ley!0 -
Blower
The blower or fan doesn't atomize the oil. The pump does this job. ED0 -
Nozzle Atomizes
On most systems, without a nozzle the fuel oil is not going to be atomized.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
