flue damper
RJ_4
Member Posts: 484
damper: Johnson Controls makes one ,just install and plug into your existing igniton control. call 1-800-482-2778.
RJ
flue damper
I need to rplace a honeywell flue damper in a peerless steam boiler. It is a honeywell nn55422 cannot find replacement for this number can anyone help?0 -
Flue Damper Replacement
The current Honeywell Series Number is D896:
http://customer.honeywell.com/techlit/pdf/68-0000s/68-0186.pdf
Also, Field Controls makes flue dampers:
http://www.fieldcontrols.com/gvd.php
And a third company that makes flue dampers is Effikal, but I'm not a big fan of these as they have a problem with not fully opening and causing no heat problems0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
