steam heat
stan_11
Member Posts: 2
Hi. Last night on the steam pipe going into our radiator, about 6 inches below the wall, steam was escaping from a point on the pipe. When we turned off the heat and examined around the pipe where the steam was escaping we couldnt feel or see any cracks or holes. Also, when the heat shut down the pipe was soaked in cold water. A friend of mine recommened plumber's epoxy putty. Is this a good idea or is there a better solution? i can be reached at 347-239-1257
Stan- No point in using epoxy
when you cannot find the hole
Short of replacing the pipe, a couple of stainless steel band clamps and red rubber sheeting sealed with silicone can be a fast repair, both sealed and mechanical. Epoxy will only work on a dry surface and you have to find the hole. If it is a crack, the epoxy will not penetrate to seal it, just mask over it.
There are other ways, but the band and rubber method is what I have used with success. Too much success in that I have admittedly left it that way for far too long...0 -
Are you sure
something else isn't leaking down onto the steam pipe?
"Steamhead"
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
