NREL and discomfort
Mark_46
Member Posts: 312
I set my thermostat back while at work or during sleep (8 hours or more at a time) based on info from the National Renewable Energy Laboratory (NREL) that states lowering the thermostat will result in a fuel cost savings (apprx 1 % saving for each degree)
you save fuel between the time the temperature stabilizes at the lower level and the next time heat is needed, etc.
But when this one pipe system (I think 120,000 BTU) within a 1,800 sqft house is always being set back, a constant temperature difference exists between the first and second floors. If the thermostat is left at a constant setting (24 hrs or more) the first and second floor temperatures eventually equalize but obviously the savings from set back are forfeited.
Any theories as to why?
NREL and discomfort
I set my thermostat back while at work or during sleep (8 hours or more at a time) based on info from the National Renewable Energy Laboratory (NREL) that states lowering the thermostat will result in a fuel cost savings (apprx 1 % saving for each degree) you save fuel between the time the temperature stabilizes at the lower level and the next time heat is needed, etc.
NREL and discomfort
Discomfort and the NREL
Which floor is warmer?
Can we assume that this is a steam system, and the thermostat is on the first floor?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
