hot rod
Sweet_2
Member Posts: 143
for clearing Solarol. Whats the max pressure you would use when blowing out tubes. Thanks .
Just a re-post incase hr didnt see.
Depending on the mood
my compressor will go to 100 or 110 sometimesIf that doesn't clear it, you are probably done.
I don't know what the tube was rated for and I am not sure the manifold connection would take that. And I probably should not suggest you use that PSI !
We remove each loop from the manifold to find the plugged ones and either clear, or eliminate them.
The high psi is usually a last ditch effort! Start with 30 psi and work up.
George, now with Slant Fin, stops in here ocassionally, he was involved with the Solaroll early on and may have more pressure data.
Good luck.
hot rod
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
