insultarp R-value
In general, most tarp products stack up around an R1 to a 1.65, depending on how generous you want to be and the particular product used.
Waste of money, IMHO.
Do they affix a R value to underslab insulationn like insultarp? My builder/associate is interested in speaking with an engineer to use this indsulation in lieu of 4' perimeter insul only. Engineer does not know about suggested radiant heat in this small wharehouse
Thanks Rich0 -
Weblink
Go here:
http://www.healthyheating.com/Page 55/Page_55_o_bldg_sys.htm
and do a bit more Google research if you have time. Insultarp is NOT an equivalent for good old rigid styrofoam type insulation, and don't forget the vertical perimeter edges of the slab too.0 -
R-value hijinks
... and if you ever see any word or words before the "R," such as "effective" or "equivalent" or "directional" or "up" or "down," do yourself a favor and RUN!0 -
performs similar to..
always makes me chuckle. How similar? Really similar to, or sort of similar to
Would ANSI have a definition for "similar to"?
hot rod
Thank You all for the help-
Rich0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
