sunrad radiator grate clips
bob young
Member Posts: 2,177
burnham or governale dealer could order them. hi-heat rustoleum or any oil-based spray paint should work well.
Clips for sunrad radiator grates
Does anyone knonw how I can get a couple of dozen clips that hold the grates at the bottom of cast-iron sunrad steam heat radiators? Also, what is the best paint [not spray] to use on these radiators. My wife wants them white, not grey.0 -
Thanks for the tip. Unfortunately, my wife doesn't like, or want spray paint in this application. Can I just use a good alkyd or enamel paint?0 -
Yes, a good alkyd/enamel paint is fine. As always, good preparation is the key to a long-lasting paint job. Scrub with a fairly strong detergent and rinse well.0 -
have it powder coated0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
