GSHP advice? (GrandPAH)
[Deleted User]
Like Thermomax or Ergomax work great and also serve as a DHW preheat, which is a continuous every day load.
For fan coils, we like First Company. I think they now have a variable speed ECM blower motor that can be operated based on pressure delta.
Welcome to the greener side of the lawn :-)
EDIT: TurboMax, not ThermoMax. TurboMax is made by THermo2000.com why I'm cornfused?
ME
ME
buffer tanks, etc...
For those of you who have past GSHP experience, I'd appreciate some pointers regarding buffer tanks for domestic hot water pre-heat and any preferences you have regarding chilled water air-handlers.
Every inquiry we've gotten needs a combination of radiant and A/C with one that will be incorporating PV & thermal solar. Lots of interest, so I'm certain we'll be entering the areana.0 -
Dave, Short on time, but
here is a set-up we have been successful with. This illustration does not reflect the controls for reset to the floor heat system, but could be incorporated with proportional mixing or VSIM.
The buffer tank is key in that we bring the system return in thru the boiler drain. We use a Marathon heater as a buffer and one of the element tappings house the bulb wells for both the Heating and Cooling aquastats. The other element tapping is used for heat supply from the GSHP.
DHW is preheated with a DHW generator package within the GEO unit itself and piped as shown. All pumps have integral flow checks because we are extremely cautious when in Cooling/Chiller mode and don't want chilled water thru our floor heat system.
I have found the control wiring to be a bit involved, but since most of it is low-voltage, it's do-able. I would LOVE to see a Tekmar TN4 system with geo capabilities.
Regards,
PR0 -
Paul, where do you get Marathon
element tap adapters? I recall that being an odd thread.
hot rodBob "hot rod" Rohr
dp
Omaha Hydro Pump
has the adapters in stock. 800-728-0878. Good people to work with.
Regards,
PR0 -
Geothermal Buffer Tanks
Hi Dave,
I have been using some of A.O. Smiths larger storage tanks as buffer tanks. They offer both horizontal and vertical tanks which come in handy when you are in a crawl space. We have just finished a home where we used two Geosmart Energy heat pumps to heat the house. One was an open loop (water-to-water)to do the radiant and the second unit was a closed-loop (fluid-to-air)to do the A/C,ventilation and supplemental heating using forced air zoning (Intellizone).Geosmart is out of Cambridge,Ontario.0 -
That Marathon tank sure gets around
I see a bunch of solar suppliers offer it with either a "hot stick" HX screwed into it, or external HX's.
Be nice to see some bigger sizes. Sure are nice to carry around
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
