REpco Boilers
joel_19
Member Posts: 931
I love Repco!!!!!!!!!!!!!!!!!!!!! I wish there where so many more of them out there , job security.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=254&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Does anybody
have or know of a contact # for info on Repco boilers.
Thanks
Repco Boilers
Repco has been out of the business since the early to mid 1980's. What is it you are looking for?
Glenn Stanton
Manager of Training
Burnham Hydronics
U.S. Boiler Co., Inc.0 -
I think they went out in the early 80's. What info do you need?? They are referenced in the Hydronic Rating Handbook.0 -
Thanks for the reply\"
a wholesaler that I use is looking for a replacement boiler for a church and were hoping to do a direct replacement.
Snicker
giggle... chuckle...."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
That's
probably one of the poorest quality boilers ever made.They are not missed
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Damn Brad you can be sooooo cruel
However I've heard also that it's cruel to be kind the very first time.0 -
I hear....
Once removed from their base, a chain through them makes a good mooring.
Do yourself a favor and run a REAL heatloss. The guy who put this thing in most likely did the old three finger method. Chris0 -
Oh boy!!
sounds like a real fan favorite.
Repco
Repco was a builders unit. Not real high quality. Actually, believe it or not, some of the Repco boilers were similar in design to some Crowns, New Yorkers or ThermoDynamics, though the latter are of higher quality. It depends on the model. Having a pro look at it can help you decide. The verticle tube designs are not the most efficent way to go. A low mass or condensing boiler with an indirect water heater is better.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
