Infloor Sensor
hr
Member Posts: 6,106
I used the tekmar 500 series or the Wirsbo equivlent.
On the past few jobs I used a simple basic setpoint control. I mount it in the mechanical room, as they are not the nicest looking control. But it also keeps folks from "over adjusting"
The tekmar is a nice conmtrol, tough to wire, odd shape doesn't cover a 2X4 electricial box, and somewhat confusing to homeowners to adjust and program.
I'm going with the Heattimer setpoint as it has a large display and is very simple for the average homeowner to drive.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
What do you guys typically set the in floor sensor to in bathrooms and kitchens?
Jamie
Thanks Hot rod! I mounted the two bathroom sensors in the linen closets and the kitchen in the pantry. I have them set to maintian a floor temp. of 70 degrees. Do you think that is enough or too much?
Jamie0 -
If the sensor
is mounted to the bottom of the subfloor, I've found somewhere around 85 or so. It depends on the r value of the build up above the sensor.
If the sensor is emmbedded in the backerboard or touching the tile itself 78-82 seems to be the comfort range.
Most times mine are installed under the 3/4" subfloor and the tile backer board.
Bottom line, let the owners adjust it till it hits their "sweet spot"
I back my bathroom floor stat about 5 degrees in the summer time. I like to just take the chill off the tile without overheating the space.
The main reason I am changing stat brands is to allow the owner ease of operation to fine tune to their comfort range.
Keep the differential tight, 2-3 degrees is about right, I've found.
hot rod
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
