New Tool(non heating)
Ed_26
Ed_26 Member Posts: 284
Looks Great!
who makes it? where do you buy it/how much?
  • EJW
    EJW Member Posts: 321
    New Tool
    I just got a chance this weekend to finally use my new water pump puller. I think theres a few guys here that do well work. If you do, and don't have this machine you need to get one. It is a god send for the one man shop like myself. It made this 335ft. set childs play. I aplogize for the cell phone picture quality.
    EJW
  • Weezbo
    Weezbo Member Posts: 6,232
    i have seen that...
    seems like a good thing.
    my thought was 'I wonder if a person could use Wirsbo instead of pe pipe...?...' the water should cool the pipe making it stiffen up a bit...:)the well drillers here are pretty much stuck on the idea of metal pipe....
  • 1\" PEX
    thats all we use anymore with split-ring compression fittings, its specs are better than most PE pipe so why not?
  • EJW
    It is made by Pull-A-Pump in NJ. I don't think they have a web site yet but are working on it. I bought it with optional equipment for a little over $6000. EJW
  • harvey
    harvey Member Posts: 153
    PVC pipe?
    Almost everyone here uses Schedule 80 PVC pipe, usually 1"
    Would this machine work on that? Alot of wells go down 300' or more.
  • Josh_10
    Josh_10 Member Posts: 787
    I think that I saw that on This Old House a couple of weeks ago...
  • EJW
    Yes it will
    I pulled a couple that were 450-500 on poly pipe. It has extension poles and a hoop at the top so you can pull 20 ft. sections of rigid pipe, put it through the hoop to hold it then cut it off or unthread. EJW
