munch
f the builder
Member Posts: 9
in planning a radiant system i noticed the new munchkin wall mounted unit does anyone have experience with this yet? will i get more noise transferred through the wall then if i sit the old model on the slab floor? this will be right next to the master bdrm thats the main reason for using the munch unless anyone knows of a similar unit that is quieter.as always best source for info thanks guys
You know these ModCon boilers are so quite! Or am I just going deaf? Seriously am I?
You know the burners are just so stable that there is almost no vibration. I use motor mounts between the boiler and the wall just to be safe though. Works wonders.
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
