munchkin install
Couderay
Couderay Member Posts: 314
Afew pics on my own install in Wisconsin,please be kind lol.
  • Brad White_153
    Brad White_153 Member Posts: 28
    Actually that is a very nice installation!
    Neat and orderly, nice poured concrete pad (no patio blocks!), spacious and easy to follow, looks easy to service. Plumb and level. Solid use of unistrut, everything looks well supported.
    I would be quite pleased with that installaton, Joe.
  • Couderay
    Thanks Brad I will sleep better tonight and have floor pics of copper if interested again thanks as you have my utmost respect on the wall.
  • nice install
    I wish i had that much room for some of my installs. easy to follow and nice job with the hangers. Did you use the vision one? I have had to replace a few out door sensors this year so do your self a favor and purchase an extra one.
  • Couderay
    Thank you, yes I used vision one do have an extra one (out door sensor)did silicone the openings where wire went thru and knock on wood,no problems of yet.
  • Ross_7
    Ross_7 Member Posts: 577
    Bell & Gossett pump
    Joe,
    Looks good, but you have to change the position of the PL Bell & Gossett pump. Manufacturer doesn't recommend mounting with the motor on top like that. Other than that, job looks O.K.
    Ross
  • Couderay
    Yes,you are right, it has been changed
  • hvac-tech
    hvac-tech Member Posts: 36
    dhw ex-tank
    air psi set in DHW EX-TANK. need to be for DHW .
    Not at 12psi.
  • Couderay
    That part of the system is not hooked up yet, going to try gravity feed for the domestic.System (potable hot water)runs on a 40/60 set up on incoming water.What pressure on the tank do you recommend.
  • hvac-tech
    dhw ex tank
    air psi in DHW EX-tank. 58PSI
    ON A DW PUMP SWITCH AT 40/60 psi
  • hvac-tech
    LONG DAY
    HAD A 14hr day today not to bad
    it was "oil free "
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Test Case- Joe
    You must have had some good (good??) cold weather to test this one out. How is she running?
  • Couderay
    Don't know
    Well I really don't know to be honest,right now it idles at 55 degress,thermostat settings. Big problem is I live 450 miles from this boiler. Only get up there 4 times a year and twice when it is cold,hope fully can get there the week between Christmas and New Year. This project is an ongoing thing. Radiant in basement floor and fin tube in house.Neighbor goes once a week to check things out for me. This is my first boiler install and probablly the last one at this size. Not like the behemoths I build and maintain at work. I could go on and thanks for asking Brad because if I every have the chance I want you to engineer the system for me.
