Thermostat and gas valve???
work.
Thermostate 24v: gas valve 20v?
I have just installed a thermostate with a rating of 24v.
Will it work OK with a gas value rated 20v?
Thank, Dallas0 -
Thank, Dallas0 -
O.K.
I wasn't aware of 20v gas valves.0 -
not for nothin
I am by no means a heating expert, but isn't a thermostat just a switch, like a lightswitch. So it would have a voltage rating, but would not affect the voltage passing through it. So, as long as the voltage and amperage capacity of the thermostat are not exceeded, I would say it should work fine., oops, I realized someone already answred,...but arent I smart0 -
Some older solnoid
valves were listed as 20 volt valves years ago and may still be around on some equipment. They work just fine with 24 volts and the thermostat is just a switch so it is not a problem. Just make sure you match the anticipator on the thermostat to the amperage draw of the gas valve.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
