One pipe steam system 4 radiator vents are spitting water,
Advanced Mechanical
Member Posts: 5
I have a one pipe steam system with 15 radiators 4 of which spit water. I have flushed all of the returns and confirmed that they are returning during operation. I have replaced all of the air vents in the building, The only returns are on the heal of the 90's at the bottom of the risers. 5 returns in all. the sytem is running at 1/2 lb all of the radiators are pitched properly. the boiler was replacd 8 years ago and they never had this problem. It started at the beginning of this heating season. HELP
Maybe you're making wet steam?
try flushing and skimming the boiler. It's probably best to have a pro do this. If you introduce cold water to a hot boiler, it could crack!
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
