Gorton 54 disc type vent valve
brucewo1b
Member Posts: 638
and ask for a 1/4 X 1/8 Black bushing as see below
http://www.plumbingfittingsdirect.com/black1/60100.html
Does anyone know if this is appropriate for venting a steam convection type radiator. I have four of these in my house, three have 1/8th inch opening and an adjustable hoffman air vent. For some reason one has a 1/4 inch opening and hoffman didn't supply a vent of this size. I believe what is on the rad now is a small Gorton 54 disc vent valve. This rad does not get very hot.0 -
Gorton 54
As far as I'm aware, this isn't something you should find on a steam system, it's meant to separate air from water and vent it in hot water systems.
You should bush the 1/4" down to 1/8" and use an air vent intended for steam.0 -
Does anyone make an air vent that would fit 1/4 inch on the convector? Not sure how one bushes 1/4 to 1/8?0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 893 Plumbing
- 5.9K Radiant Heating
- 379 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
