Water level in furnace
Dan_15
Member Posts: 388
I have a forced hot water heating system. When I press the water valve to add water to the furnace (sometimes referred to as the boiler) the water gauge level dutifully rises. However, within a few minutes it declines. Every few minutes there is a sound that erupts from somewhere in the system, which sounds like a valve is opening and/or closing.
I do not see any leaking water in the vicinity of the furnace.
Perhaps related to the above, when I set my thermostat to e.g. 65 degrees, it only reaches a temperature several degrees lower than what I set it at.
Can anyone diagnose my problem and suggest a simple, do-it-yourself solution, before I contact a plumbing/heating expert on Tuesday or Wednesday?
In addition, who would you recommend for repairing this problem if you don't have the wisdom to solve it on your own?
Sol Schimmel
Sol Schimmel
Sol, a furnace and a boiler are two different systems all together. You are referring to a steam boiler. Go to "Find a pro" on the top left of this page and find someone to take care of your problem for you. With all due respect, a simple fix for someone that doesn't know the difference between the two could be more than just a small problem.
Good Luck...............ROOKIE0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
