need some advice with my steam boiler.
karl_2
Member Posts: 7
thank you
i have a steam boiler that cuts off before the t-stat is satisfied and wont come at all. someone told me to rise the pressure at the pressure contrl for steam a little bit. it was set at 3psi. it wont kick in till i adjust it to 7psi is this normal..? I dont think so.. i was told residential boilers need at least 2psi of steam steam to heat the house. plus the gage is stuck at 10 psi and never went down .. i know the gage is broken but is there something else like maybe i missing . could it be a bad pressure control.
__________________0 -
stean advise
crank it down to 1 1/2 lbs less pressure the better it will run sounds like the pigtail the pressuretrols attached to is plugged replace the gauge
thanks ed but are you saying the pig tail attach to the pressuretrol is clog thats why i have to rise the control to 7psi to run? please respond thanks..0 -
Yes that is the probable cause0 -
Karl, that pigtail can act like a \"roach motel\"
if the pressure was up when it plugged...."the pressure gets in, but it can't get out!". This can hold a pressuretrol open so the burner doesn't run.
Might be time to call a pro.
thanks
thanks so i will clean the the pig tail or buy anewone also changethe pressuretrol and gage since the gage is broken.0 -
Beware...
Sometimes they are very hard to clean. If the thing is ancient, it can break off at the threads when you try to take it out. Just be gentle.
Ed0 -
thanks every one. yes i change the gage and the pigtail that was conected to the pressuretrol that was fill with nesty stuff. it was not clog but had alot of rusty particals inside.set the pressuretrol to 2psi diff 2.= cutout 4psi worsks so fine. im an ac and heating apprentice so i know just a little about boilers. thank you everyone. i will make a contribution to the brick soon thaks....0 -
need some advice again.
need help again i just change my gauge on my steam boiler and the needle wont move can some body tell me why please thanks..0 -
Low Pressure
Most steam systems operate with less than 2 lbs of pressure, which is not enough to indicate on most guages.
Codes require those 15 lb guages, but on most systems, you'll never see them move.
Long Beach Ed0 -
Gauge
In a normal home you may never build enough pressure to move the gauge. Sounds like it is fine.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
