Steam Piping
a foot ? Is it so any condensate falling down the 1st riser doesn't get picked up with the steam into the next riser ?
Header Piping
I seem to recall reading somewhere (most likely on this sight) about minimum distances between the tees connecting the boiler steam risers to the header and where the system riser connects to the header. Should there also be a minimum distance between the system riser and the equalizer?
John T.0 -
Ideally,
about a foot.Retired and loving it.0 -
It keeps the carryover
from bouncing off the equalizer elbow and up into the riser.Retired and loving it.0 -
Ahh , I see
But is there a minimum distance we should keep between 2 risers going up , off the boiler main ?0 -
Nope
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
