275 Gal Vert standing 12G oil tank
tom_49
Member Posts: 269
Mark,
The legs on all oil tanks if they are approved should give you years of reliable service.
If you are interested Roth makes an aluminum tank with a plastic liner ( dual wall ) . Do a google search for "Roth oil tanks".They are being required in some of the towns where i live in SE Mass.
Good luck
Good luck
Oil tank question
Hello all--I was just wondering--How well are the bracket welds that hold the tank legs? I was thinking today as i received a fill up--the weight of a 275 gal tank filled--WOW!!! I would also like to know--if anyone knows of a support-that maybe goes under the tank incase one of the leg welds break...My tank is OUTSIDE its about 4 years old--and it looks good.. I just have this thing on my mind that a leg weld is going to break--i can only imagine what would happen.... Thanks have a great day/night... MARK0 -
in 17 yrs. ...
I have never seen a weld on a leg break...I f yoy protect the tank from the weather It should give you many years of service. kpc
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
