One Pipe Steam Heat and NewThermostat
Ray Joyce
Member Posts: 1
I replaced out dated Thermostat with a new Honeywell programable. The boiler turns on and off more often now then when with the old thermostat. The radiators do not get a chance warm up, but the desired temp. is maintained. The constaint on/off is that bad for the system?
Thanks, Ray
Thanks, Ray
Did you set up the dipswitches for steam heat or hot water vs. the default? This will cause it to run longer cycles, but cycle less and will be more efficient.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
