drill$tap steam pipe
tom_11
Member Posts: 58
I have two steam pipes one is 1.25 dia the other is 2" dia,the ends of the mains have a plug on them and are to close to the cement wall. If i drill the two pipes and tap them , with a one half inch drill should i drill the tee and tap it there. with out harming the tee,s thank you tom
I would drill the pipe, not the Tee.Steve from Denver, CO0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
