Steam Radiator Valves
Thanks Al. I'll give it a whirl.
  • Paul Fredricks_3
    Paul Fredricks_3 Member Posts: 1,557
    2 pipe
    I have a customer with a large 2 pipe steam system. 3 of regulating valves at the radiator are blowing a lot of steam. I assume the packings are shot since trying to tighten them did nothing. Can these typically be repacked? If so, what do you recommend using?
  • Al Letellier_9
    Al Letellier_9 Member Posts: 929
    steam valves leaking
    Yes, typically you can repack them. Best to use a graphite packing material. Teflon string packing can also due the job but doesn't seem to stand up as long. You can get graphite at any good supply house or a packing and gasket dealer.
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    Paul, you may find
    that these are "packless" valves. If so they will have to be rebuilt. Tunstall supplies rebuild kits for most valves.
    www.tunstall-inc.com
  • Paul Fredricks_3
    I checked out the valves today. I take off the cap nut and can then pull out the stem. It sits on a spring and the stem has a flat surface that mates to the bottom side of the cap nut. Seems almost like it should be a lapped seal. I can push the stem down a bit and put in a line of teflon rope. This seemed to make the valve feel a bit better, but then the house lost a leg and I can't get the boiler to run. No way to test it. Great timing.
    I didn't see rebuild kits for this type of valve on the link you gave me.
