Base board covers
Fred Brustman
Member Posts: 2
Does anyone know where I can get a steel cover for a baseboard heat exchanger in a circulating hot water system (1960s vintage)? The existing one is about 5" high, rolled top and bottom to clip onto supports attached to the back plate behind the aluminum fins.
You Kidding Right ?
You don't like new baseboard ?
If you can find a name
you might find a supply house near you that can help you out, if not try
Radiant Wraps
Radiator Cover0 -
do a google search on coverall0 -
Replacement baseboard covers
Its not whether I like them or not, one of the existing panel covers is damaged. I'd like to replace it if I can.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
