fuel pressure testing
helpingothershelpthemselves_2
Member Posts: 326
Westwood Products kit and Sid Harveys Kit .
Sid's kit also has Riello capabilities.
fuel oil pressure testing
What name and model gauges do you guys/gals use for testing and setting fuel oil pressure and testing vacuum? R.E. Michel has two that look reasonable. 1) Ritchie 2) Fuel unit test kit. Thanks for any advise. -Michael0 -
Any Cheap gauge
..... for testing normal pressure and vacuum and pump pressure. I use a Riello pressure gauge. A set of vacuum gauges that replace the bolt in the 1A & 2A filter. I also have Sid harveys oil watchmen vacuum gauge with the clear line. Have a funky Monarch kit that I never used..
I mostly use the set of cheap gauges. If you loose them or they break..no big deal0 -
kits
I'm a big fan of pre-packaged tools that are set up for a specific task. I use a cheap gauge , a short regrigerant hose , and some brass fittings in a plastic lined " travel " case ( meant for toothpaste and shaving cream " ...LOL.
I want to buy a nice sid-harvey kit this year ( and a " Soot Vac " of my own ). If I get some good side work , I want a new combustion anylizer too ( my Lynn needs an O2 sensor ).
My motto is.. " Buy the best tools available. There will ALWAYS be better mechanics , but people will remember that I had nice tools , LOL " ...or..." Tools don't make the technician , but good tools and a poor mechanic equal an ok mechanic " LOL.
Really , get a kit in a molded plasic or a metal case with a brand name on it. The manufacturer makes a ton on it , but provides you with a means to do a job in an organized manner. -Mike0 -
I'd get
the new combustion analyzer first, or get the Lynn fixed. These days you can't get by without an analyzer.
I agree 100% about the analyzer. Just finished my second class with Jim Davis, 1st was back in 2000. My Bacharach tech 60 has a failed o2 sensor and this is the second repair within 1 1/2 years. So I recently purchased the tsi 6130 and love it. Thanks for the replies. -Michael0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
