Radiator Air Bleed Keys
Check plumbing supply houses--they usually have them. True hardware stores (if you're lucky enough to still have them in your area) often have them as well. "Big Boxes" might--if such is common in your area.
If all else fails, here's an <A href="http://www1.acehardwareoutlet.com/(d4pnec55xdfxkr452453vhyq)/ProductDetails.aspx?SKU=40676&Source=froogle">on-line source</A>.
  • Roy_11
    Roy_11 Member Posts: 1
    Air Bleed Keys
    Moved into our house with h/w radiators last year and had one old zink plated key for the radiators and have lost it now and I was wondering if there is a place in the US to buy these little devils? All that I can find are in the UK and I would think as many rads as there are in the US surely there would be a place to get these keys. Thanks for your help.
