Tankless coil produces low volume of hot water
Wayne_21
Wayne_21 Member Posts: 1
I have a Utica ACE 400-ST boiler with a tankless coil for hot water. I am the sole occupant of the house and don't use much hot water. The water gets scalding (200 deg.) hot but not for long enough to take a 10 minute shower without cooling off and then hot again as the boiler kicks in. This is probably the original coil from 1978 so I'm guessing that it is full of minerals from the very hard water here.
The boiler is geting up there in age but heats the house just fine. Should I get a replacement coil? I've replaced heating cores in cars. Is this any more difficult or should it be left to the pros?
  • Weezbo
    Weezbo Member Posts: 6,232
    an anti scald valve is the first ticket....
    and the answer is yes the coil is not the easiest thing to deal with.....
