Kickspace on Prestige 110 boiler (thermo switch?)
hr
Member Posts: 6,106
switches for most brands. Or go to Johnstone Supply and get an adjustable click type fan switch.
If the water temp is to low, however, they will blow cool, not warm air.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
I've installed a Prestige 110 boiler for a customer, on a baseboard loop there's also a 8k btu kickspace heater. With the outdoor reset and cooler supply temps I don't believe the KS thermo switch will kick the fan on very often? Should I wire the fan up directly and take the kickspace power supply off the zone circ relay?0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
