zone valve flow
Hard to say for sure without seeing it, but usually the flow should be OK either way. When questions like this come up, photos are always a big help. If you are not having any operational or comfort problems, I wouldn't lose too much sleep over it.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Jorge
    Jorge Member Posts: 26
    I have two zone valves in my system. One for each floor. The pipe comes out of the top of the boiler then turns 90 to a tee. One zone is on top of the tee the other z valve is on a 90 off of the t from the first z valve. Is it ok to have a 90 on the last z valve or should there be a tee with a cap on the end.
