Determining Radiator EDR
Steamhead (in transit)
Member Posts: 6,688
The ornate ones, correct? These appear in Dan's book "E.D.R." which you can get in the site's online store. But if you already have a chart for standard column radiation, you can use it for the Rococo.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
American Radiator ROGOOD (?)
I'm trying to determine the EDR for a neighbor's radiator setup. Most of them are American Radiator ROGOOD series with different numbers of sections. The radiators are 32" tall by 7 1/2" deep. Is there a certain value per section and I just multiply by the number of sections?
Thanks,
Larry C0 -
sizing rads
Do you mean Roccoco Rads? You can size them. You need the width, height, number or tubes or columns and # of sections. Check the library for the sizing charts
sizing rads
Thank you
Thank you. As you might guess, 400 or so layers of paint makes it a bit difficult to decipher the letters.
Larry0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
