Painting of radiators
John_127
Member Posts: 1
We recently moved into a 100+ year old home and the steam heat radiators are more than likely original to the home. All of them have numerous coats of paint on them. Is this a problem? If so, how do we fix them?
Also, how do we remove a radiator that is no longer needed?
Thanks in advance!
Thanks in advance!
Under tech topics or library there is a great article on rad paint. Sandblast them first. The color and paint type does matter.
What type of steam heat do you have?
TimJust a guy running some pipes.0 -
Removing a radiator
I believe the best technique (using one hand only) is to carefully manipulate your mouse to go to the top left corner & click on Find a Professional. How do you know you don't need that rad?0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
