steam heat
Good answer Bill, I`m surprised "Steamhead" isn`t here, he usually knows it all!
Steam Heat
Radiators are not getting hot. Return on two pipe system seems to be flooded.0 -
'R U ?
Are you asking ? Or simply stating... ?
Well I guess you would have to figure out why the return is flooded. Maybe a bad return trap ? Overfilled boiler?
Check the water level in the boiler, drain off water if you have to. If the return is flooded the radiators won't heat because the steam won't get into them.
The returns could plugged with rust or sludge you may have to flush them.0 -
Well
sometimes I have to go out and work too!
James, you need a steam man. Try the Find a Professional page of this site. It's always easier to diagnose the problem when we can actually see the system, especially Vapor where it could be one of dozens of variations.
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
