What could this be
... is called a range boiler. In winter, the real boiler would heat it, providing hot water. When the main boiler was off in summer, the side arm heater would be used to heat the range boiler. With no insulation on the tank, it was likely fired up only when somebody wanted a bath ;~)
Do you see a name on the side arm heater? It looks interesting.
Yours, Larry
