Which side of the system for circulators?
Ted_9
Member Posts: 1,718
I think his plumber owes him a 4 pack.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=373&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Circulators placement?
Ill make it short I was a B&G tech 15 years ago,thne they said that circs went on the supply side of the boiler(hydronic) now I am replacing my own boiler and have three zones piped with flow checks my buddy the plumber LMP says to put them on the return and they will basicly suck open the flow checks.what does the wall belive what hte wall says I will do and if the wall agress with my buddy he gets a 4 pak of guiness-
thanks in advance0 -
supply
You're right, they should be on the supply, mainly to get the expansion tank on the suction side of the pumps. In general, pumps should push, not pull.
-Andrew0 -
Pumping away
I pipe everything this way. Expansion tank/air eliminator, then circs and or zone valves, all on the supply.
I am with
ANdrew and Ted, so what do you get other than pumping away.0 -
Sorry double post
pump away ..:)
its the right way to roll:)0 -
look at it this way ...
he just saved the plumber call backs... maybe he ought to get a boiler maker A?
There i go speaking Canadian again
and wash it down with the 4 pack
supply, supply,supply
Tell ur plumber buddy to SUPPLY us the beers...... In my dad's 1954 something B&G book, shown some systems have pump on the supply side... Found a old National U S boiler manuel (1963) stating pump should be on supply side... Let us know if ur buddy needs the address from us to send the beer....0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
