From our friends at NARI
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,643
FOR IMMEDIATE RELEASE
CONTACT: Gwen Biasi or Stephanie Manola
(847) 298-9200
gbiasi@nari.org or smanola@nari.org
Green Remodeling 101
It IS Easy Being Green
October 5, 2006 –Des Plaines, Ill. –- It’s hip to be green. And remodeling a home green is easier than you think. The National Association of the Remodeling Industry (NARI) just launched its new Green Remodeling educational program, offering remodeling contractors across the country a unique opportunity to incorporate cost-saving and earth-sustaining green concepts into their clients’ homes.
What is Green Remodeling?
NARI’s approach to teaching Green Remodeling is an all-encompassing approach that emphasizes making a home healthy, comfortable, and efficient. Consideration is given to indoor air quality, energy conservation, resource conservation, reduced material waste, and the use of products that are better for the environment (and for people).
Why go green?
It’s easier on the earth, it lowers costs, and it provides a healthier home in which to live. According to the Sustainable Building Industry Council (SBIC), housing alone consumes 20% of America’s energy. Homeowners who choose to remodel green can lower their energy consumption by 30-50%. It’s widely agreed that forests produce 40% of Earth's oxygen, and that building supplies use 25% of its forests. Remodeling green by incorporating recycled materials or sustainable species will help homeowners to tread more lightly on Earth’s natural resources.
Green remodeling is becoming more popular as homeowners consider health issues, skyrocketing energy costs and Earth’s natural resources. More than 15 million Americans are estimated to have asthma, including one-in-13 school-age children, and more than 28 million Americans suffer from hay fever and other allergies, all of which are aggravated by poor indoor air quality.
NARI President Everett Collier, CR states, “Remodeling Green offers every homeowner the opportunity to reduce home energy demands, lessen home maintenance costs, and increase comfort. Remodelers are increasingly exploring green remodeling principles for their overall value for their clients and for the sake of the environment.”
The new Green Program at NARI helps remodelers do just that. “If a remodeling contractor seeks to develop knowledge and skill in the area of green remodeling,” says the Chair of the Green Education Sub-Committee, Chris Donatelli, CR, CKBR, “the NA RI Green program will help realize those goals. This program thoroughly educates the contractor who desires to focus on environmentally friendly remodels.”
Facets of Green Remodeling
Energy conservation
The average home today utilizes systems for heating, ventilation, and air conditioning, and most homes are not built as efficiently as they could be, all of which results in high energy consumption. The U.S. Department of Energy believes if current buildings were green-improved, they would use $20 billion less energy per year. Green remodeling puts a strong emphasis on making homes as efficient as possible with modifications like energy efficient appliances and thermostats that can be programmed at different temperatures for different times of the day.
Indoor air quality
There are many sources that contribute to the air quality inside a home. They include pollutants brought in from the outside, toxic chemicals existing inside the home, and the activities of the occupants that create pollutants. Major contributors are tobacco smoke, smoke from the burning of wood, coal, kerosene or other such substances, toxic fumes from sealants or chemicals from cleaning products, lead paint, asbestos from insulation, damp carpets or fabrics, and certain pressed-wood furniture products that release chemicals into the air. Green remodeling seeks to remedy these problems with things like better ventilation systems and using wood, paint, and sealants that are nontoxic.
Reduced material waste and resource conservation
When remodeling a home, there is often a large amount of construction waste. This amounts to 136 million tons of waste annually, according to the EPA, which in turn makes up 20% of the waste in landfills. Green remodeling focuses on reducing this waste during remodeling and reusing materials whenever possible, as 85 to 90% of materials thrown out can be recycled. Using local materials, building with engineered lumber, and using recycling companies to remove waste are all ways this can be achieved during remodeling.
Environmentally safe products
Many products and practices used in the remodel of a home have negative effects on the environment. From chemicals and materials that pollute the air to the disturbing of the surrounding landscape, a myriad of actions taken can cause harm. With green, care is given to minimizing or eliminating products that could cause harm to the environment or the occupants during remodeling or after.
Benefits
Overall green remodeling proves to be very beneficial for homeowners. It:
Reduces operating costs in the home by increasing efficiency
Conserves natural resources
Increases the value of the home
Improves indoor air quality and in turn, overall health
Reduces waste
Reduces emissions costs
Increases productivity of occupants
Improves quality of life
Ways to Implement Green Into Your Home
Green remodeling can be done in small ways and doesn’t necessarily have to encompass the entire home. It’s easy to pick and choose elements that fit each particular homeowner.
Non-toxic paints and sealants
Programmable thermostats
Energy efficient appliances
Natural flooring
Local building materials
Natural fiber rugs and fabrics
Recycled material roof shingles and tiles
Energy efficient lighting
Insulated hot water pipes
Tankless water heaters
Quality insulation
Native plants for landscaping
NARI members represent a select group from the approximately 800,000 companies and individuals in the U.S. identifying themselves as professional remodelers.
The remodeling market, projected to be a $291.5 billion industry in the U.S. in 2006, is expected to continue to experience significant growth. It is estimated that more than a million homes per year undergo major renovation or remodeling.
NARI is a professional association whose members voluntarily subscribe to a strict code of ethics. Consumers may wish to search www.RemodelToday.com to find a qualified professional who is a member of NARI.
Consumers can also call the NARI National hotline at 800-611-NARI and request a free copy of NARI’s brochure, “How to Select a Remodeling Professional,” or visit www.RemodelToday.com and click on the homeowner’s guide for more information.
About NARI: The National Association of the Remodeling Industry (NARI) is the only trade association dedicated solely to the remodeling industry. With more than 7,400 member companies nationwide, the Association -- based in Des Plaines, Illinois — is “The Voice of the Remodeling Industry.”TM For membership information, or to locate a local NARI chapter or a remodeling professional, visit NARI’s website at www.RemodelToday.com, or contact the national headquarters office at 800-611-NARI.
Retired and loving it.
