AM-10 for the GB buderus's
Ray Landry_2
Member Posts: 114
Hey guys any one have the opportunity yet to use the AM-10 card for the GB buderus to enable outdoor reset? I'm installing one next week, and am hoping it will be included with the boiler, according to buderus's website it is shipped with all GB's now. I'm gonna make sure to spec it, I can't wait!!! Anyone know exactly how it works? can you still use the RC 10 with an outdoor reset curve as well? is the curve easilly adjustded? Joe? any comments?
ray
make sure you spec it. I just hung a GB on the wall tues. did not come with it. But I got four extra o-rings : )
Buderus rc-10 and outdoor reset not yet compatible
check out this prior thread:
http://forums.invision.net/Thread.cfm?CFApp=2&&Message_ID=261912&_#Message2619120 -
RC10
The AM10 module is now sent with each GB142. There is a program to handle GB142's that are in stock at distributors. The RC10 and AM10 cannot be used together. The AM10 is very easy to install. The module "snaps" on above the draw assembly. The plug to tie the AM10 to the GB142 is already on the wiring harness. Install the outdoor sensor. Connect the thermostat or end switch to the "T T" terminal on the AM10 module. To program the AM10 all that is required is inputting the "reference temperature" and what temperature is the heating curve starting point. The GB142 will be a cold start unit till there is a call for heat. The GB142 will fire up to the heating curve temperature.0 -
so there is an additional 'program' that needs to be purchased when using the AM 10?0 -
The "program" I was referring to is how we are dealing with the GB142's that are in the distributors inventory, but do not have the AM10 module.0 -
ok joe, thank you0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
