new boiler Utica
Anthony Menafro
Member Posts: 199
Have you developed leaks in the system that caused the boiler to constantly feed make-up water? This is a big problem that is very bad for the boiler right at the water line.
Anthony Menafro
Anthony Menafro
Im in the process of installing a new steam boiler. the plumber is coming tommorrow for an estimate. He wanted to install a new yorker but i explained that my utica boiler installed now is set low on my chimney. So he was thinking of installing another utica. My question is with the new yorker i was saving money, is the utica much more expensive? or is there another brand anyone can recommend that is good and not too expensive for low chimnies?0 -
oil or gas
the draft hood on gas units usually is the problem.0 -
it's gas0 -
The Utica steamer
is actually taller, but doesn't require a top mounted draft hood. Crown, Burnham, Weil, Dunkirk, Peerless has these side mounted draft hoods on their models. Maybe you can get a good price on one of those models.0 -
the utica im removing now has a leak above water level. Its going on 23 years old. Shouldnt they last a bit longer? THats why im hesitant about a utica again. All my radiators heat fine but i cannot raise pressure anymore? Am i using more gas right now?0 -
i noticed every year it was needing more and more feed water. I learned fresh water corrodes the boiler. THats why im replacing rather than attempting to get a repair.
my plumber came yesterday and saw the chimney was low. he recommends i get a weil mclain, he claims they are shorter. i need a 150000 btu boiler. specs on the website show its 33 to 34 inches high.0 -
Is there space to break into the chimney higher up and seal the lower opening with some bricks and mortar?
Norm Harvey,
Independent Burner Service,
Weymouth, MA0 -
there is room to break another opening.the chimney is not brick.its mason or mortar, im not really sure. also there is a lining inside. i dont know if that will effect it also0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
