Adding water loop to steam system
Bob W._3
Bob W._3 Member Posts: 561
This article is found on this site:
http://www.heatinghelp.com/heating_howcome6.cfm
Should answer all your questions. Boiler capacity will not be affected.
  • Alden Maddry
    Alden Maddry Member Posts: 17
    Adding water loop to a steam system
    I have a one pipe steam system that I would like to modify. I will be adding a greenhouse onto the back of my rowhouse and I want to determine whether I can tap into my existing steam system to heat the greenhouse also. A home inspector told me that there is a way I can add a "water loop" onto a steam system. He said that this would work better than installing additional steam radiators off the system. Does anyone know about doing something like this? Will my boiler capacity effect whether I can do this?
