Pressuretrol / Gas Valve compatibility?
Casinojunkie
Member Posts: 36
I beleive I have a pressuretrol problem.
I do have a Honeywell PA404A Presuretrol which is for 24 volt gas valve, I have in service a BASOID Model B4451-B1 gas valve which is 20 volts; .95amps. Can I use this presuretrol with this gas valve?
PA404 is a 120 volt and
24 volt and millivot pressuretrol it can do any of those three. It will work fine with the gas valve you have.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
