Steam Mains
John S.
Member Posts: 260
a parallel flow one-pipe system. This is a good setup if that's the case.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=366&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Should STEAM MAINS pitch up or down from the boiler?
The longest steam main run that I have on my system, about 46 ft., appears to pitch downward as it moves away from the boiler. This seems counterintuitive to me if steam rises. Just a guess.
Which way should a steam main pitch as it moves away from the boiler? Thanks!0 -
Steven, I 'm going to assume that you have a 1 pipe system. The steam mains perform 2 functions. They have steam at the top and condensation water at the bottom of the same pipe. So they act like a steam duct and a condensate drain pipe. A parallel system the steam and the water move in the same direction (away from the boiler) In a counter flow system the steam moves away from the boiler and the condensate flow back toward the boiler. In this case the pipes would pitch back toward the boiler.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
