Radiator At Boiler level
Vlad
Vlad Member Posts: 16
Works on my hot water system to force hot water down to basement rads, may work for steam also.
  • Aires
    Aires Member Posts: 2
    Radiator at Boiler level
    I have a radiator in the basement, the bottom 3/4 of it is level with the water level of the boiler. Needless to say this radiator doesn't heat well if at all. I replaced the air valve, but this leaks whenever the heat comes up. I have a one pipe gas fired steam heat system.
    This radiator is mounted about 18 inchs above the floor with both inlet (feed) and outlet (return) pipes on the left side.
    Short of repositioning the radiator 30" above the floor is there a way to rectify this?
  • Gary Fereday
    Gary Fereday Member Posts: 427
    Click on the left
    "hot tech topics " and have a read!
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,321
    Who put that there...
    ...and did it ever work?
    Ed
