kickspace heater
Brad White_50
Member Posts: 6
The KSH pressure drop plus the elevation drop may be thwarting you. You may need a monoflow tee both in and out, especially if the other runs are much less in pressure drop.
Those clip on aquastats are IMHO not very accurate nor adjustable. Granted you do not want cold air blowing, but I have defeated them by wiring those leads to a line voltage thermostat as the primary control for the heater. Try putting a jumper across the terminals and see if you get any heat. May also be that the water temperature is too low. Capacity drops off rapidly. KSH's generally do not "do reset" well.
Went to look at a kickspace heater today done by another mechanical company.It is an addition in a garage 1 thermastat on 2nd floor and garage below with an entry way where the kickspace heater is.Basicaly turn thermostat up bled kickspace heater quiet one series heater will not come on put heat gun up to aquastat, heater ran basicaly cant see above finished ceiling no idea which way monoflow tee's are going is it possible tee's are installed backwards and that is why. or that there is a 8' drop to heater then has to some way circulate back up.Do you think for my first step without cutting ceiling open is to reverse lines that feed kickspace heater.please help0 -
kick space heater
I think your idea is the best way to start try cutting kickspace loose and using rubber hoses as temp lines and see what happens since you have already ruled out the aquastat as the problem only thing i can think of the lines are reversed
Do you think tee's would be a problem if installed backwards.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
